1942 Case SC
J. Irwin
09-07-2006 11:04:07
PLEASE I NEED HELP!!! We just got a 42 Case SC and need help finding parts and information. If anyone has any info or has a Case SC and restored it please let me know. Thanks J.Irwin
L.Lamp
09-10-2006 11:47:17
 Re: 1942 Case SC in reply to J. Irwin, 09-07-2006 11:04:07
If your '42 has not neen updated to 3 5/8" bore from 3 1/2", find an auto machine shop that does reboring. Find a good set of 3 5/8" pistons and have the block rebored to fit the largest piston with proper clearance. You do not have to take the sleeves out, but I would pull them and replace the seals once they are bored. The crankshaft has to be out to do this. If your crank is good, which I doubt, send your old main shells to Don Livingston and ask for the size your crank was reground to. I have 4 sets of these bearings from Don. I use my tractors for show, pulling and plowing events. I rebuild them to work as good as new.
mark sergent
09-09-2006 19:05:23
I am working on a 1954 SC that i bought to play with. Found many parts except for main bearings . I know that on the bore for the SC there is a standard bore and a oversize bore about a 1/16th larger. The parts books show oversize pistons for these engines. I have seen liner/pistons/rings sets but they are expensive. I have some seal numbers for the shafts. Chevy 350 exhaust valves can be cut down and the guides reamed for the chevy valves. If you have access to a valve machine this will save you a lot of money. Any help I can give I will but I am just started out with Case. I have owned Ford and John Deere so Case is a new one to me. Good Luck Mark
jheitkemper
09-07-2006 21:37:03
I have a complete 42 and 44 that couldbe restored or parted ..,,,what do you need ?
fredct
09-07-2006 18:04:06
I just finished restoring a 44 SC and have many parts left over - although probably not the ones you need like sheet metal, etc. Give a shout here on this site and folks will help you out and keep scouring Ebay - that is where I got most of the stuff I needed. Good-luck, Fredct
John Saeli
09-07-2006 11:22:52
Let us know what you need. Been lots of SC's restored.
