manifold for a C
M. in sask
09-05-2006 17:41:50
I have the C running but needs choke on 3/4 to run good . The intake exhaust manifold was broken from frost which I welded, I an thinking possibly its broken inside causing a intake leak. any thoughts? Where can I get a new or used manifold? any help would be appreciated Thanks Merv
boston bean potty
09-06-2006 22:54:10
 Re: manifold for a C in reply to M. in sask, 09-05-2006 17:41:50
don L mite have one in minnesota..507-433-0073
mshultz
09-06-2006 05:10:55
I have a dual fuel on my C that I'd like to replace with a gasoline manifold. The temperature "flapper" is not in it - just two bolts with a threaded coupling in between and touch of high-temp silicone to seal it up. Doesn't leak a bit. Aside from the missing flapper, it is in excellent shape. Let me know if you're interested.
Camboted
09-06-2006 02:15:30
If you don't need a dual fuel manifold try John Saeli.
