Case-O-Matic slips
Noel Ditmars
09-05-2006 10:49:00
Case 800 transmission slips so that the tractor will hardly move in any gear. Changing the transmission filter did not help. Any suggestions as to what to do next? Sell it for salvage?
John Saeli
09-05-2006 17:37:56
 Re: Case-O-Matic slips in reply to Noel Ditmars, 09-05-2006 10:49:00
If it's bad, parts are still available. My vote is to fix it.
WBWi
09-05-2006 17:28:56
Just a couple of thoughts, first is the pedal comming up all the way there is a spring that tends to break on the pedal or it could be rusted, also there is a relief valve on the filter housing (you will need to remove the square part on the right side) they had a tendency to go bad. You should have a gauge on the unit to see what pressure you have, it has been awhile but the gauge should be around 150psi If not there is a relief valve located on the control unit that can be shimmed up. If it isn't any of those things the unit itself will need repair and salvage would be an option.
