Water in Case 630 differential
JGarner
09-04-2006 19:18:18
Took the brakes off today because oil was seaping out of vent hole on bottom of the brake cover casting. On the right side one cover stud thread broke out before the nut did so I just took it out instead. When I got it out it was draining water from the differential housing. I caught about 6 Qts of water and 16 Qts of oil from this hole. Where did the water come from? The engine block is still full because I checked. I was afarid of in internal crack that was leaking water throtug the torque tube, but it doesn"t look like the torque tube on the 630 communicates with the differential like on the older tractors with wet clutch.
As soon as I am finished with the brakes I am going to remove the top cover on the differential and flush it, or should this be done first? The water did not look rusty like it does from a radiator that has been run in an engine with no antifreeze. I hate to look inside for fear of what I might find.
Also, could not find the drain plug where am I over looking it?
JG
amo
09-05-2006 07:46:06
 Re: Water in Case 630 differential in reply to JGarner, 09-04-2006 19:18:18
i just flushed out with diesel, drained again and refilled with proper oil, no damage, keeping it under cover now. good luck
JGarner
09-05-2006 13:48:32
 Re: Water in Case 630 differential in reply to amo, 09-05-2006 07:46:06
That is what I had planned to do. I guess you did remove the inspection plate and look inside. That is probably worth the cost of the large gasket, or maybe I will be able to see inside with a flash light well enough when I pull the bearing carriers out to relace the seals as part of my brake repair procedure this weekend.
amo
09-05-2006 05:04:22
probably from condensation or leaking around gear shift on top, my john deere b wsa the same way. good luck
JGarner
09-05-2006 05:39:56
 Re: Water in Case 630 differential in reply to amo, 09-05-2006 05:04:22
So what did you find in the housing when you got inside. Much damage, little damage? What, if anything, did you replace because of the water?
