Chain drive 930
Ohio Case
09-04-2006 18:38:51
Will the chain drive 930, (earlier models) hold up to a stock 504? Better question, does the 504 bolt up to the older style rear end like the later 930 & 1030??? This would be used for tractor pulling only. Thanks in advance
PaulD
09-05-2006 20:15:48
 Re: Chain drive 930 in reply to Ohio Case, 09-04-2006 18:38:51
If your 930 has a hand clutch it won't work unless you do some modifications to the crank shaft. The 930s with a hand cluch have a hole in the end of the crankshaft to aid in the oiling of the wet over center clutch. The 504 doesnt have that hole, it might be expensive to machine to work also.
WBWi
09-05-2006 08:43:02
Even though they look alike,it is my understanding that you cannot interchange engines between the 6 and the 8 speed 30 series Case tractors,even with modifications.
Camboted
09-05-2006 07:32:49
I think the chain drive 930's were the toughest tractor ever built. Can't say that for the 8 speeds, even though they are a good machine. I believe the blocks will interchance, but could be wrong. LOL
