cant get cav pump off
nate005
09-04-2006 11:13:29
db 995 tractor. I took off the nuts and lines but pump moves but wont pull off , any suggestion?
Thad
09-04-2006 17:09:06
 Re: cant get cav pump off in reply to nate005, 09-04-2006 11:13:29
Did you remove the bolts that hold the drive gear on? There is plate on the front cover you will have to remove to get to these bolts. If you havent done this be very carefull not to move the gear around. If you happen to jump teeth it would be out of time. Hope this helps.
nate005
09-05-2006 05:52:51
 Re: cant get cav pump off in reply to Thad, 09-04-2006 17:09:06
what front cover are you talking about, is it on the pump or tractor.
Thad
09-05-2006 13:12:14
 Re: cant get cav pump off in reply to nate005, 09-05-2006 05:52:51
It is located on the front cover of the engine. You will need to remove the lower radiator hose to get to it.
