49 Case DC Clutch Adjustment
Jim Mitteer
09-03-2006 06:00:34
I have successfully adjusted the clutches on my L and CC tractors but I can't seem to find the adjusting yoke lock pin on my DC. Is there something different on the DC assembly or what???
dctom
09-03-2006 09:35:14
 Re: 49 Case DC Clutch Adjustment in reply to Jim Mitteer, 09-03-2006 06:00:34
they are about the same but there is a little round top pin you must (PUSH IN) and turn it the oppisite way kind of hard to find but it is in there tom
Jim Mitteer
09-03-2006 16:30:28
 Re: 49 Case DC Clutch Adjustment in reply to dctom, 09-03-2006 09:35:14
I took off both covers and looked all over the yoke and could find nothing. I wiped everything down with solvent and a rag to make sure I didn't miss something. This doesn't even look like my CC or L clutch. Is it possible that somone put later clutch parts in? I just got this tractor so I haven't had a chance to get a parts and operator manual.
dctom
09-03-2006 16:38:16
 Re: 49 Case DC Clutch Adjustment in reply to Jim Mitteer, 09-03-2006 16:30:28
your right dont look like cc or l at all, that round button is in there sometimes marked with a spot of white paint it will be in side of the sort of frame work around the clutch plate DC all from about 44 had the new style clutch that you pulsh the pin in insted of pulling it out tom
Jim Mitteer
09-04-2006 09:26:00
 Re: 49 Case DC Clutch Adjustment in reply to dctom, 09-03-2006 16:38:16
I found the button. Clutch works great! Thanks for your help.
