What;s wrong with my d?
JAL
08-31-2006 20:19:18
I can operate my 1940 model d all day pulling a wagon, working a buz saw or just running it around. When I put it under a load like disking or plowing it becomes hot and spits antifreeze out the radiator cap. The radiator level is down about 2 inches. I have completely gone through the engine a couple years ago and the shutters are open all the way. Anyone got any ideas? Thanks
C. Amick
09-01-2006 09:07:12
 Re: What;s wrong with my d? in reply to JAL, 08-31-2006 20:19:18
Pull the radiator cap off with the tractor running. You should see a lot of swirling action if the water pump is working correctly. Is there a thermstat installed in the top radiator hose?
JAL
09-01-2006 20:14:06
 Re: What;s wrong with my d? in reply to C. Amick, 09-01-2006 09:07:12
There is a lot of swerling in the radiator. The radiator was cleaned and eodded out 2 years ago. There is no oil in the radiator or water in the oil. There is no thermostat in the tractor. I will check the timing and other itms listed. Thanks for the info.
Walt Davies
09-01-2006 08:47:03
It could be a lot of little things or one big thing. Check your timing. Check the radiator for flow it could be a bad pump a blocked radiator a blocked engine. Rust in the system. Blocked radiator from dirt in the fins. A hot day. High altitude. Boy this could go on forever. Low oil. Low oil pressure. You really just need to start at the beginning and look the whole tractor over. It could be a bad head leak or head gasket leak, look for bubbles in the water when under a load. Fill the radiator clear up for this test. Over heating can be caused by a lot things you just have to eliminate them one by one.
Walt
CASEPOWER
08-31-2006 20:27:23
I would check the radiator core. It may not be flowing enough.
