Case Aircooled engine
Kevin brambrink
08-31-2006 19:51:14
I went to the local salvage yard today and found an engine that I have never seen before. It is a air cooled 4 cylinder case motor,I bought it as the price was right. I can not find a tag anywhere on the engine. Any help would be nice.
thanks kevin
CASEPOWER
08-31-2006 20:22:47
 Re: Case Aircooled engine in reply to Kevin brambrink, 08-31-2006 19:51:14
Case air cooled engines were used in tobacco setters and posibly a couple other items. They were advertised as a power unit. It is a 219 series engine. It is 126 1/2 cubic inch and 30 hp at 2000 rpm"s. It would be great in a VAC!
CK RICHARD
09-01-2006 16:39:54
 Re: Case Aircooled engine in reply to CASEPOWER, 08-31-2006 20:22:47
I've never seen a case tobacco setter or a self propelled setter do you have a picture?
Air Cooled
09-01-2006 10:04:14
Case used them mostly on pull-type combines, self-propelled windrowers and balers.
Roger (Mi)
08-31-2006 20:55:54
 Re: I bought one also in reply to CASEPOWER, 08-31-2006 20:22:47
Found and bought it in Minnesota this summer. Was told that the air cooled Case engine was often used on combines. Was also told that it's easy to install into a VAC. Have plans to install mine on an irrigation pump which currently has no engine.
