800 Heads on a 400 motor?
Rick Taylor
08-31-2006 18:37:51
An acquaintance told me that it is possible to put 800 diesel heads on a 400 diesel tractor. Is this true? Is there any modifications required? How difficult to find good 800 heads?
My 400 diesel heads are in need of a rebuild and now would be a good time to improve if possible.
Thanks for any advice!
Dale Roisum
09-02-2006 08:57:21
 Re: 800 Heads on a 400 motor? in reply to Rick Taylor, 08-31-2006 18:37:51
I finally found a pair of heads for my 800 that were not cracked. The best I can tell is the heads from the later serial numbers (400 super diesel) are the same as the 800 heads. Both were 267 ci. I do not know that the earlier 400 block would accept 800 heads.
dboll
09-01-2006 04:59:02
alot of 400's have 800 heads on them, 30 series have a differen't bolt pattern.
J,Heitkemper
08-31-2006 22:45:22
From What I understand they are the same .possible that the 30 series split heads will work as well .It is a good idea to Magniflux for cracks around the Injector ports ..
J,Heitkemper
08-31-2006 22:45:04
