steering 930
paul nelson
08-30-2006 22:29:35
I have a case 930 square mudguards (932)and the steering is stiff in places. OK on the straight but hard on turns. The belts have been replaced and tight could the hydrolic pump be on the way out or could there be something else wrong? The pulleys are worn as it squeels on the turns any ideas.
Paul
Eagle Doc
08-31-2006 22:16:27
 Re: steering 930 in reply to paul nelson, 08-30-2006 22:29:35
Your last sentence is your answer. If the pulleys are worn and don't fit the "V" shape of the belt they will slip. If the pump slows down too much it won't pump. It is expensive but you probably need new pulleys.
Camboted
08-31-2006 16:37:30
What we have found is that the problem is often in the steering gearbox. You would never suspect it but you could have bad bearings and it really messes up the worm drive.
R Wyler
08-31-2006 05:19:05
Mine is acting very similar I even put on a wider belt as the pulleys are worn on mine also and it still squeels something terrible especially when I turn and speed the engine up. I have had the cylinder rebuilt and I have bled and bled it its getting very annoying. I am wondering if the pump needs rebuilt. Oh by the why I tried the pump off my othere 930 and to no avail and another spare pump I aquired and all 3 pumps do the same thing.... I am getting tired of this.....
John Saeli
08-31-2006 05:26:02
 Re: steering 930 in reply to R Wyler, 08-31-2006 05:19:05
What we have found is that both the P/S Belt & the Fan Belts have to be really tight. The fact that the belts squeel is a good sign. The pump should be OK. It's hard to believe, but if that small P/S Belt is good and tight, those 2 Fan Belts will slip if they are not real tight. When I say "Tight", I mean rocking them tight with a bar. It's that slipping that wears out pulleys.
c hess
08-31-2006 17:47:38
 Re: steering 930 in reply to John Saeli, 08-31-2006 05:26:02
Your problem if your 930tractors are the ones with a couple u joints as used on 730 830 930 1030 is they are dry an rusted. A quick fix is to squirt a penetrating oil on them while you have tractor off ground an turn steering an fork in grease. If you are very carefulyou can get it on u joint under radiator an not on belts!!!!! !! I have just tore my 930 apart an put a new cross in that one from napa 15 dollars -it is a needle bearing u joint an you need to remove radiator . Other ones are plain joints an i just packed with grease. I did not do those in steering pedestal hoping because they are protected they will be ok . Steering is now ok . Remember these tractors are 40 yrs old an when i removed needle joint it fell apart in a rusty mess.
R Wyler
08-31-2006 11:14:19
Thanks for the tip I will try tightening those fan belts.
