Hi All - I was changing the oils in my new VAC - had drained the hydraulic with the engine off and then let the mower on the 3 point down to see if any more oil ran out the drain. It did. I started filling it back up, with a funnel fit tightly into the fill hole, when I realized it had filled to the fill hole and left some oil in the funnel. Instead of draining some out, I fired up the tractor and raised and lowered the mower again thinking it would suck up some of the excess into the rear cylinder. The mower raised and lowered as normal, but when I came back around, the funnel was full of very foamy oil and sort of spewed over like a coke can fizzing up. Is that normal? Would you think there is anything wrong that needs to be looked at - like the pump or the rear cylinder? I"ve been around a lot of other more modern tractors, but never saw one foam up the hydraulic oil like that... Thanks for any insight, Howard H.
