430 -530 parts
Rob Baird
08-27-2006 14:24:09
HI I have a 530 CK. I have located a 430 parts tractor. Will tires wheels and other parts interchange. The lugs on one of my rear tires have been welded to the center.Mine has 16.9x24 tires on it. Not sure about 430 as have not seen it yet. Wanted to know how much would interchange first Thanks for your help Rob Baird
JGarner1013
08-28-2006 07:27:20
 Re: 430 -530 parts in reply to Rob Baird, 08-27-2006 14:24:09
Talking commonality, how much of the 530 general purpose tractor is common to the 630 series general purpose? I have a wide front adjustable axle 641. I am looking for a few odds and ends and am wondering if 530 parts may fit as well, I think the 730 series is physically larger.
BKahler
08-28-2006 04:02:44
Be careful about the rear wheels. My 530CK came with a spare wheel with a decent tire on it. I finally made the swap to the spare wheel and found that it had a different offset and wouldn't work on the 530CK. Not sure what the spare wheel was off of but Case definitely made several different wheel offsets.
Brad
RMvcGuffin
08-27-2006 19:26:23
I am looking for either an entire standard PTO assembly for a 430 or a gear or two for the PTO. After you get your parts tractor, I would like to talk to you aboutwhat parts you might have available.
