400 Case tractor
400Case
08-27-2006 11:14:52
I went and looked at a 400 Case diesel row crop today. Narrow front, factory power steering, 3 point Eagle Hitch. Fairly straight tractor with poor original paint except one fender is missing and the other is rotted. Doesn't look to have been abused except that one head has been just replaced and I noticed it had a ether kit installed. Brand new 14.9 x 38 Good Year tires on the rear and the front are good used but are on oversized on newer/wider rims because it had a loader on it at one time.
Serial number from block is 8084685. I could not see a tag anywhere. What year is it?
The guy wants $1500 for it. How much should it be worth?
Thanks
Lewis hooker
08-28-2006 12:08:48
 Re: 400 Case tractor in reply to 400Case, 08-27-2006 11:14:52
If the tractor run an the lift works it should be price in that range more are less,It don't show a picture of the 400 Case,Email me back on that 400 Case
Lewis hooker
08-28-2006 12:23:57
 Re: 400 Case tractor in reply to Lewis hooker, 08-28-2006 12:08:48
I need a steering box for a 400 case Diesel 1957 year make tricycle if any one has this part could you email me, Thank you
Lewis hooker
08-28-2006 12:03:49
C. Amick
08-28-2006 09:21:26
Seems like a good price to me. I gave $1,600 for my Case 300 gas and the rear tires were worn out and it ran but needed engine work.
Triplerange
08-28-2006 05:12:28
If it runs...I'd think that was pretty darn reasonable.
Doc Larry
08-27-2006 19:39:01
I don"t know about the row crop version, but I"ve got a wide front 401 diesel which is a very good tractor. With the good tires on the one you"re looking at, I don"t think price is out of line unless it has a major problem you"ve missed. But I don"t know what you plan to do with the tractor. I use mine.
An ether injector was factory equipment.
Larry
1200 TK
08-27-2006 15:34:39
Hi "400"CASE, Your tractor, CASE "400", Serial No8084685 was built during the 1956 production year.
Regards
Alan T.Lewis
Christchurch
NEW ZEALAND
