SC Case rocker arms
chub
08-27-2006 10:31:18
Rocker arms badly worn and can not ajust tappets [too loose]. Any one know where I can get good replacements?
george md
08-27-2006 15:34:09
 Re: SC Case rocker arms in reply to chub, 08-27-2006 10:31:18
Chub, Are the bushings worn or are the tips worn ? If it is the tips ,I have the material and the way to regrind them.
george
chub
08-28-2006 12:59:31
 Re: SC Case rocker arms in reply to george md, 08-27-2006 15:34:09
George, wear is at the point the rocker arm pushes on the valve. Bushings seem tight. What is the process you do here? Replace and grind the push tips [for want of better words]? Thanks for your reply, chub
george md
08-28-2006 14:14:27
 Re: SC Case rocker arms in reply to chub, 08-28-2006 12:59:31
Chub,
I spray weld the tips with a material that is as hard as the original , then i have a fixture for grinding the radius on the tip . Email me .
george
chub
08-28-2006 14:26:22
 Re: SC Case rocker arms in reply to george md, 08-28-2006 14:14:27
George, e-mail sent, chub
george md
08-28-2006 17:08:48
 Re: SC Case rocker arms in reply to chub, 08-28-2006 14:26:22
chub,
Answer the phone
george
Chub
08-28-2006 17:25:45
 Re: SC Case rocker arms in reply to george md, 08-28-2006 17:08:48
George, Been to town to a wake. Wish you would have left a return phone number. Home rest of evening, chub
