Case 830 vs. 831
Nate in IL
08-26-2006 13:16:18
Folks-
What is the difference between an 830 and an 831. There is an 831 for sale cheap and it needs a hyd pump. Are they interchangeable? Are wide fronts available for the 831? Any major issues to watch out for?
Thanks
Nate
Gary in Pulaski
08-26-2006 16:49:00
 Re: Case 830 vs. 831 in reply to Nate in IL, 08-26-2006 13:16:18
Hydraulis Pumps are a common "issue" with 830"s I had 3- 830"s from the early "eagle hitch" series all the way to my latest "Comfort king". Around here, if the bone yard has a pump, we"ll pay upwards of $900, as is. Always run the hyd system 2-3 qts OVER FULL to heep oil at all bearing sites at all times. Go for it! Pretty economical to run for the horse power class.
Ron 1456
08-26-2006 14:36:26
An 831 is an 830 Diesel. An 841 is an 830 gasoline. I don't know about the LP. All fo them had an 830 decal on the hood. I would think you could find a wide front at a salvage yard.
Roger H
08-26-2006 16:49:57
 Re: Case 830 vs. 831 in reply to Ron 1456, 08-26-2006 14:36:26
The 841"s are LP or gas, the 1 means it is a row crop version either wide or narrow front
