Trade anyone?
Dave in IA
08-26-2006 07:10:04
I have a lot of stuff that I took off my 1948 VAI and would sell or trade for stuff I need. I HAVE a generator and relay. I HAVE a complete air cleaner and riser. I HAVE all the lift mechnism for the cultivators including the hydraulic cylinder. I NEED a water pump pulley. I NEED a fuel tank. I NEED one rear wheel.
Sam#3
08-28-2006 10:36:14
 Re: Trade anyone? in reply to Dave in IA, 08-26-2006 07:10:04
Sorry, I have nothing to trade but I would be interested in BUYING an air cleaner. E-mail me with a price if interested (and still have it).
Sam
Dave in IA
08-28-2006 11:48:07
 Re: Trade anyone? in reply to Sam#3, 08-28-2006 10:36:14
Yes, I still have it. How about twenty-five dollars plus the cost of packaging and shipping? I'll have to drain it really well in order to ship, but I can certainly do that. Of course that little bracket that ties to the exhaust pipe is broken off right at the exhaust elbow, but the bracket is complete otherwise. The whole assembly has incorrect paint as they had painted the tinware on this tractor that late model Case yellow.
Sam#3
08-28-2006 12:09:05
 Re: Trade anyone? in reply to Dave in IA, 08-28-2006 11:48:07
Please check e-mail
Sam
Bob/wis
08-27-2006 04:26:26
Dave I will check today and see what I have on my tractors here. I am located 45 mins east of Dubuque. So, if I have the goodie you need also bring a shopping list if you need other parts for them.
Later
Bob
Dave in IA
08-28-2006 04:40:31
 Re: Trade anyone? in reply to Bob/wis, 08-27-2006 04:26:26
That rear wheel rim is the main item.....that and a water pump pulley. I am also kind of interested in finding a cam-driven hydraulic pump if such a thing exists for my 1947 VAI. I saw a VA locally that had a pump mounted on the timing case....it looked factory.
Dave in IA
08-26-2006 15:36:45
I need the outer rim to fit on my cast spoke center section. The tire size is 11.2 X 28
Dave in IA
08-26-2006 15:39:27
 Re: Trade anyone? in reply to Dave in IA, 08-26-2006 15:36:45
The tractor has the usual stuff amidships....the cross bar setup, and the cylinder, and a piece of linkage; that's about it. The hydraulic pump under the pulley is gone.
Allan K.
08-26-2006 09:50:55
Do you need rear rim or actual cast wheel/hub.? What size ? I may have spare of each in E. Ia.
Dave in IA
08-28-2006 11:51:01
 Re: Trade anyone? in reply to Allan K., 08-26-2006 09:50:55
That would be the outer rim only for a 11.2 X 28 tire.
'53 VAI Guy
08-26-2006 07:14:25
What do you mean by lift mechanism? Eagle Hitch? I have a 1953 VAI and you can never have enough extra parts. Let me know. Thanks
Dave in IA
08-28-2006 11:53:48
 Re: Trade anyone? in reply to '53 VAI Guy, 08-26-2006 07:14:25
This is the old setup in the middle of the tractor
with the little cylinder on the LH side and the pivoting linkage that hooked to a mounted cultivator. It ran off the belt pulley hydraulic pump.
