Dearborne Plow
Scott
11-17-1999 10:15:22
I have got a dearborne 2 14" bottom plow. They don't have the cutting disks in front of the plows. Would I be better off making my own or trying to find them.
ernest galliford
11-13-2002 09:33:04
 Re: Dearborne Plow in reply to Scott, 11-17-1999 10:15:22
need a disk for dearborne field cultivator 13-24
serial 7310 mfg by pittsburgh forging co.
Dave in Mo
11-19-1999 10:02:36
Scott, you don't need those coulter wheels unless you are cutting sod for the first time. They are intended to slice the soil so that the dirt will flow up the moldboard more easily. I took mine off because we plow every year. Just make sure your tailwheel is adjusted correctly to take the side thrust generated by the 2 bottoms.
Larry
11-17-1999 11:07:12
Deardorn is a plow used on Ford tractors.You might have better luck on the Ford page.
