Case O Matic trouble
Paul In Ct
08-24-2006 05:28:16
I have a 530 backhoe with the Case O Matic pressurizing the bell housing. You can run about a half hour before all the oil leaks out and you cant move any more. Any ideas?
Roger (Mi)
08-27-2006 05:13:39
 Re: Torque tube oil leak in reply to Paul In Ct, 08-24-2006 05:28:16
There should be NO pressure in the bell housing or Case-O-Matic drive assembly area. There should be a vent to on top of the torque tube to prevent it. Obviously, the leak must be stopped. Try tightening the bolts around the bell housing. If that doesn't slow down or stop the leak, the tractor will need to be split and the bell housing gasket will need to be replaced.
