Case 930 CK Tachometer
Mike from IL
08-23-2006 21:22:15
I have a '66 Case gas 930 CK with a broken tach.
Any ideas where I might be able to get one? Would a tachometer out of another model Case work,
such as a 830, 1030, 900, etc.? Thanks, Mike.
melm
08-23-2006 23:47:33
 Re: Case 930 CK Tachometer in reply to Mike from IL, 08-23-2006 21:22:15
Sometimes they can be repaired. They get full of dry greese. Use a small screwdriver to work the ring crimp open. Don't use gasoline to clean them. It will harm the plastic. recrimp the ring with pliers. Do dealers or aftermarket places have new ones?
John Saeli
08-24-2006 04:56:50
 Re: Case 930 CK Tachometer in reply to melm, 08-23-2006 23:47:33
Case sells a replacement tach. Very expensive, not like the original.
JGarner
08-24-2006 05:35:21
 Re: Case 930 CK Tachometer in reply to John Saeli, 08-24-2006 04:56:50
John are you or any of our other replacement Case parts distributors refurbishing or manufacturing these tachs and same vintage gauges?
John Saeli
08-24-2006 18:47:40
 Re: Case 930 CK Tachometer in reply to JGarner, 08-24-2006 05:35:21
Nothing in the works as yet.
Phil Kruger
08-24-2006 16:47:50
I have 2 930 Case Diesel tractors & have had both tachometers rebuilt. The tractor shop I do business with sends them somewere in Arkansas.Both work fine now.
JGarner
08-25-2006 18:11:29
 Re: Case 930 CK Tachometer in reply to Phil Kruger, 08-24-2006 16:47:50
Phil, can you find out where they send them? What state are you in? I may go down and see if my local Case dealer can send mine off. Wonder if they have replacement gauges also. My instrument panel is in pretty bad shape, needs some TLC.
Phil Kruger
08-27-2006 05:06:32
 Re: Case 930 CK Tachometer in reply to JGarner, 08-25-2006 18:11:29
JGarner Im from Wisconsin.May be quicker for you to call the place that sends the tachometers in for me. The shop name is Baraboo Power Equipment in Baraboo Wi. ask for John. What state are you from?
JGarner
08-31-2006 19:56:05
 Re: Case 930 CK Tachometer in reply to Phil Kruger, 08-27-2006 05:06:32
I'm near Houston, TX.
