need info on case va
plo
08-23-2006 19:14:47
i just picked up a case va. but the tag is stamped va1. im thinking it is a vai. but it is clearly stamped 1 not i. so what does the 1 mean. the tractor is a industrial and has an industrial mower on it well only part of it but it does have the factory tag on it and it is a case mower. has live hyd. serial #6039474 i think makes it a 1955. any help would be nice as to what i have. might sell but want to know what it is first.
charley hellickson
08-23-2006 23:15:00
 Re: need info on case va in reply to plo, 08-23-2006 19:14:47
Hi What you think is a 1,one, is an I. It kinda looks like a one. What you have is a VAI.I have a 1951 VAI. I don't know about the later serial numbers after they changed them. What you might have is one of those Case Detroit mowers. They were an industrial mower with out a pitman arm. Hope this helps. Good luck. Charley.
plo
08-24-2006 03:37:03
 Re: need info on case va in reply to charley hellickson, 08-23-2006 23:15:00
thats what it is but the 1 has the hook on it just like it is wrote on here so it is not a missed up i. there is no why that i think that it is a bad stamping.
'53 VAI Guy
08-24-2006 14:11:21
 Re: need info on case va in reply to plo, 08-24-2006 03:37:03
I made the same mistake with mine. I have a VAI that I thought was a VA "1" until I chipped off an unusually placed speck of paint that made the "I" look like a "1." Check out the pics on this site and compare the similarities. You will see that the industrial front axle is much different than that of any other VA. Hope this helps.
