RPM's on a DC
36 A
08-23-2006 18:33:05
Need to increase the rpm and i"ve moved the stop and it didn"t get high enough.What spring can ichange to help me out.
L.Lamp
08-25-2006 21:04:09
 Re: RPM's on a DC in reply to 36 A, 08-23-2006 18:33:05
The last years they were made, they ran 1390 RPM with no load. That is the factory setting I would go with. To increase the RPM, shorten the throttle linkage rod to the governor spring. There is about two inches of threaded rod on the throttle rod to the throttle lever on the seat. Loosen the nuts and screw them both towards the rear of the tractor a little at a time till you get 1390 RPM at full throttle. When you move the throttle back to idle it should run at the slow speed it was set for before you started to change the linkage. If it runs fast at idle, you may need a new spring.
dboll
08-24-2006 16:49:59
tie a wire around part of the gov. spring. you can make them run faster than they should, keep it under 30% of stock, or whatever your rules apply if you are pulling it.
