300 Case Need voltage regulater 6 volt
Dave Wa
08-22-2006 11:29:08
Hi all I have been having trouble finding one all the parts stores can't find or cross over the old one. The one I tool off is a prestolite with 3 terminals I don't know if this is the original or not? It has the 148 gas motor. Is there a new type or Aftermarket that works any help if greatful Thanks Dave
C. Amick
08-23-2006 09:46:18
 Re: 300 Case Need voltage regulater 6 volt in reply to Dave Wa, 08-22-2006 11:29:08
The voltage regulator needs to be matched to what ever generator you have. An automotive electric shop should be able to tell you what regulators will work if you give them the number off your generator.
Dave Wa
08-24-2006 07:10:26
 Re: 300 Case Need voltage regulater 6 volt in reply to C. Amick, 08-23-2006 09:46:18
Thanks for all the information I will have to look and see if my generator is a match. I will keep you posted. I have a parts book coming soon till then it seems to be a mystery
case poor in pa
08-22-2006 17:15:10
if you cant do any better i can look at mine and give you the numbers.when i get home saturday. mines 6 volt i bought last year.i got it at a generator rebuilder shop
BCnT
08-22-2006 13:40:35
any 6 volt regulator can be wired to work as long as they ground the same...ie: postive ground or negative ground...my best advice to ya is check with someone that rebuilds generators/starters [not just sells]and they should be able to sell you the correct regulator.
