730 Comfort King 3 point hitch
Jim Barnes
08-20-2006 18:15:39
I have a 730 Comfort King with 3 pt hitch lift problems. Will not lift with any load .Frt end loader works great. Any ideas ?
TomVAC
08-22-2006 13:54:55
 Re: 730 Comfort King 3 point hitch in reply to Jim Barnes, 08-20-2006 18:15:39
Your 3 point contol valve needs to be cleaned. Its under the seat. Take it apart, you"ll find a steel ball that is hung up on dirt.
1030 brian
08-20-2006 18:57:26
I would check out your draft o matic control valve. Could be a check ball or spring stuck. If the loader is working you dont have a flow/filter porblem. I have a 1030, it had the sema problem rebilt it and it works fine. Good luck!! Brian
