international 444 desiel
Tom Armes
08-20-2006 07:32:24
I am looking for a block for my international 444 with a bd 154 desiel. I bought the tractor and it had water to freeze in it,and it broke from the top of the cylinder wall to the main bearing. So I either need another block which,I cannot find or the old one welded. would you know of any or recommed a good block welder? I live in the nort central part of Kentucky. Thanks Tom
C. Amick
08-22-2006 09:55:26
 Re: international 444 desiel in reply to Tom Armes, 08-20-2006 07:32:24
Does this tractor have wet sleeves? If so, did it crack through where the sleeve "O" ring groove is in the block? Look at www.locknstitch.com
Tom Armes
08-23-2006 10:41:02
 Re: international 444 desiel in reply to C. Amick, 08-22-2006 09:55:26
Yes the block does have wet sleeves,and the crack goes from top to bottom. The head gasket seats on the sleeve and making it leak proof after welding should not be a big problem.
C. Amick
08-23-2006 12:34:58
 Re: international 444 desiel in reply to Tom Armes, 08-23-2006 10:41:02
I am concerned that you won't be able to get a seal at the bottom of the sleeve between the coolant and the oil. Check with a block repair company such as Lock-n-stitch and see what they say.
Doc Larry
08-20-2006 17:59:46
Tom,
You will probably have better luck on the IHC board than here on the Case board.
Larry
