case 1175 exhaust info needed
bj52
08-20-2006 05:20:36
we have to install a new elbow and the sleeve between the elbow and the turbo on this 1175 and don't know exactly what type of gasket the sleeve takes on either end. is it a steel ring or some sort of packing? if anybody knows i sure could use some info on it.
bj52
09-07-2006 08:43:12
 Re: case 1175 exhaust info needed in reply to bj52, 08-20-2006 05:20:36
ok folks i appreciate the input. now could some one give me an idea about how much space is needed for expansion? would something like a tablet back on one end be enough? or a sheet of paper on both ends maybe? since i never seen a paper spacer i have no idea on the thickness.
bj52
08-20-2006 10:39:02
well folks i sure appreciate your feedback. two say no gasket and one says a metal gasket. the local parts place said no gasket to but it was just hard to believe that something would be designed to leak from jumpstreet especially exhaust fumes but i recon we"ll go with no gasket.
thanks again!
dwag
08-20-2006 19:15:08
 Re: case 1175 exhaust info needed in reply to bj52, 08-20-2006 10:39:02
As stated by others, no gasket was used on 70 series, only on 90\94 series used a ring\gasket with a paper spacer.
John Saeli
08-20-2006 14:08:20
My parts books are @ shop so I can't give you a number,, but all Case Turbo's, 1175 thru 4690 use a laminated metal gasket between Turbo & neck.
4435
08-20-2006 10:25:47
There should be a metal gasket as well as the paper spacer. I seems to prevent some of the smoke under the hood. Tom
JHH
08-20-2006 09:09:34
There is no gasket on either end, it is just a slip fit and needs to expand and contract as it heats and cools.
Grumpy
08-20-2006 15:45:13
 Re: case 1175 exhaust info needed in reply to JHH, 08-20-2006 09:09:34
JHH is right. The sleeve is supposed to turn free when cold. This is an expantion joint so the turbo does not bind. The 90 series used a metal fiber gasket and a paper spacer. the paper burned away and left the gasket for expantion. I have put the metal gasket on a 70 series tractors to try to slow down the smoke. Stan
c hess
08-20-2006 09:58:49
No gasket or seal in there but you might see in parts what looks like seal but is only a paper spacer that makes sure you have clearance when installing,. Burns away later.
