Should I buy a CASE?
Terry Miller
08-19-2006 04:47:37
I am currently looking at a CASE 430 diesal, PS 3pt, 12 speed trans. (high med and low range?), tin is straight, paint is good and tires are new or newer. He is asking 3500, and I have not traveled to see it yet. I have never owned a diesal, am in Wisconsin, and have a need for a tractor with a very slow low gear to use a tiller on. Also, will need to eventually put a loader on it and need PS for using in our orchard. I will need to sell my IH 300 Utility first, but wonder if anyone can give me any cautions. He said it is a let 50's but on tractordata it says they were only made in the 60's.
C. Amick
08-20-2006 12:56:59
 Re: Should I buy a CASE? in reply to Terry Miller, 08-19-2006 04:47:37
I like Cases, but what's wrong with the IH 300? Is it too fast? The 430 should be an early 60's model. Find out all you can about the engine. Diesel engines are expensive to rebuild. You might want to go with a little larger tractor to operate the tiller.
bcdave
08-19-2006 13:06:46
In my collection I have a 1960 430 and a 1967 430 with a front end loader. Both tractors are used in our orchard. We did break a pto shaft rotovating in rocky ground that should never be rotovated. The 67 is an orchard model with low front and back tires and because of the length it is great for hauling bins. It came with turf tires on the back but to narrow it down we put on 24" rims and 12" tires.
The 67 replaced a VAO that my dad bought new in 1947. The VAO was still being used when I started restoring it. I also have a 37 C and a 29 L. They are built to last.
Hope you enjoy it
Dave
c hess
08-19-2006 07:26:01
Had a430 for many yrs an cant imagnine twisting a shaft . Not enough power in 430 to do that unless something went wrong to equipment that caused pto to stop suddenly. Good tough trouble free tractor - go for it.
John Saeli
08-19-2006 06:16:14
Hey Terry: The 430 was made from '60 thru '69. Hard to say what it's worth, depending on how things are inside. $3500 is at the high end. I have heard of problems with the PTO's when using a Tiller. We had a neighbor with a 430 who had a problem snapping PTO shafts, inside the tractor.
Roger (Mi)
08-19-2006 06:39:24
 Re: Snap PTO shaft? in reply to John Saeli, 08-19-2006 06:16:14
I live in an area where there a numerous small truck farms. Having a Howard rotovator on the back of a 430/530 Case is the norm. In all of the years working for Case, I never saw a snapped PTO shaft. It's possible someone could have very heavy ground and just a few blades on the tiller. That would cause vibrations and eventual metal fatigue in almost any small tractor.
John Saeli
08-19-2006 06:45:39
 Re: Snap PTO shaft? in reply to Roger (Mi), 08-19-2006 06:39:24
We have very heavy, somewhat stoney clay. It was a Howard. Gave the dealer fits.
