governor
jbulle
08-15-2006 17:43:34
Anyone remove the mechanical governor and replace it with something more modern on a case 530-541 series tractor - Fuel pump controller or electrical rpm limiter ?
Thanks
Roger (Mi)
08-16-2006 05:31:34
 Re: Electrical RPM limiter? in reply to jbulle, 08-15-2006 17:43:34
Electrical RPM limiters are usually set for a specific RPM. (Example) It prevents an automotive engine from exceeding 7000 RPM. On a tractor, you want to have the engine maintain variable speeds. If you set the hand throttle at 1750 RPM, you want the engine to maintain 1750 RPM, etc. An electrical limiter will NOT do that. For tractor applications, the mechanical governor cannot be beat. There are governors that fit between the carburetor and the intake manifold that work on vacuum. Again, most of those are designed to limit specific RPM's. You're money and time ahead to repair the mechanical governor.
