P.T.O slips on a 970
JarrodS
08-14-2006 22:41:31
My pto is slipping when under a load on my 970, I've never had it give me any problems before. The tractor has about 8,000 hrs on it, I think its the clutch disks that need to be replaced. Any info or suggestions would be appreciated---If anyone knows how big of a job this is that would be good to know as well.....thanks.
TomVAC
08-16-2006 06:29:44
 Re: P.T.O slips on a 970 in reply to JarrodS, 08-14-2006 22:41:31
Something easy to check is to make sure the pto valve is fully engaged. The cable may not be moving the spool far enough.
4435
08-15-2006 15:43:10
Check your pressure at the flow divider valve first. Needs to be toward 200 psi. If you have to replace the plates etc. the hydraulic pump and Pto housing must come off. Tom
