Timing a 1941 VC
KiwiCasefan
08-14-2006 15:16:37
My Dad and I have been driven to distraction trying to correctly time our tractor.
We have placed the No1 cylinder at TDC (like it says in the manual) and have spun the mag til the impulse on No 1 lead. But to no avail.
The mag is a non-standard one - but it sparks in the correct order (1-3-4-2). We have noticed two different marks in the flywheel - One a big dot (this is what we have been lining up to), the other has the words 'ing' stamped on the flywheel - is this the correct mark?.
I'm sure that there is something really simple that we are doing wrong. If anyone could enlighten us, I sure would appreciate it.
MMB
08-14-2006 16:56:22
 Re: Timing a 1941 VC in reply to KiwiCasefan, 08-14-2006 15:16:37
Did you have the governor off? On those Continental engines with a mag ignition, the governor gear must be timed to the engine's camshaft gear first. This is done so the governor slot is in the right orientation (horizontal or whatever) relative to the magneto which will couple (later) to the governor gear slot. This is done with the magneto off and viewing from the drivers end of the tractor. Let me know here if the governor was off and we'll move on from that point.
Gene Dotson
08-14-2006 16:44:40
Kiwi;
First, make sure that #1 cylinder is coming up on the compression stroke. Remove #1 spark plug and hold your thumb till you feel compression pressure. If you are turning it with a hand crank, you can feel when the piston is at top center as there will be a few degrees of rotation of very light pressure. Find the proper mark on the flywheel or much easier make a mark on the front pulley that lines up on a good reference mark. Trip the impulse past #1 firing position, then back it up to where the drive lugs line up and install the magneto. Rotate engine 1 3/4 turns till #1 is coming up on compression, then very slowly turn the engine till the impulse trips and stop there. Look to see if the marks line up or are close. The impulse should trip on #1 cylinder right at top center.
The IGN mark is the mark to line up on with the engine running checked with a timing light.
My tractor has the flywheel marked with TC for top center.... Gene
MMB
08-14-2006 15:43:39
KiwiCasefan
08-14-2006 16:58:49
 Re: Timing a 1941 VC in reply to MMB, 08-14-2006 15:43:39
Many thanks for your replys so far.
In answer to MMB, no we have not had the governor off at all.
Prior to removing the mag, I dabbed a bit of red paint on the Magneto lug and it's mating slot on the governor side.
By experimentation we have found that at TDC the red painted slot sits at about 4 O'clock, yet when I trip the impulse for No1 lead, the lug sits at about 8 O'clock.
