VAC Case
Howard H.
08-13-2006 22:36:52
Hi -
I just bought a VAC Case with 3 pt.
The oil in the tranny looks pretty milky like it has had water in it. Is the tranny oil common with the rear end? Are both common with the hydraulic system?
What type oil is best? Regular commercial hydraulic oil?
The old girl runs like a top but only gets about 20 pounds of oil pressure up while revving up - is that too low?? What is normal?
Thanks for any info...
Howard H.
Joe (Wa)
08-13-2006 23:31:20
 Re: VAC Case in reply to Howard H., 08-13-2006 22:36:52
The transmission and rearend are the same sump. Factory oil was SAE 90 gear oil, 80-90 is often used. Capacity about 7 gals. Water contamination is generally rain water through a deteriorated shifter boot, alternately over a period of time from condensation.
Assuming your tractor has the Eagle hitch with engine mounted pump, hydraulic reservoir is the torque tube (the transition housing between the engine block and the transmission). Factory oil was 5,10, or 20 wt motor oil pending ambient temp, later 10-30 motor oil, general purpose hydraulic oil is commonly used. Capacity is about 2 gals.
Engine oil pressure should run 12-20 psi at full loaded rpm @ operating temp.
Joe
