Hydraulic leak\ and other
R.D.Vaughn
08-13-2006 15:20:26
Case\HI 485 runs great on start-up, I mow for an hour or so, leak gets worse and then tractor will stop running, give it 10 min will start back up but will not run well untill it has set in the barn overnight, ARE THESE TWO ISSUES RELATED?
R.D.Vaughn
08-18-2006 10:32:16
 Re: tractor wont stay runnin in reply to R.D.Vaughn, 08-13-2006 15:20:26
case diesel 485 international,the problem has gottn worse seems, it has a fuel problem.
changed filters,still no change starts great get rpm up to 1600 for pto runs solid for a min or two, then it drops down to 500 back to 1600 back to 500 and so on then dies or. is there a filter infront of the distibution pump? need help lots of help!!!!!
JGarner
08-14-2006 07:03:47
 Re: Hydraulic leak\ and other in reply to R.D.Vaughn, 08-13-2006 15:20:26
I have also seen gas engines refuse to run or start if the points are gapped too close. Seems they get enough metallic expansion in all the distributor parts to close up. Happened to one of my friend's car at my house one day when we were teens.
Dad knew what it was. He had us let the car cool off a bit and it started right up. We shut it down and regapped the points to the proper gap. (Dad was a mechanic by trade.)
Walt Davies
08-13-2006 22:27:26
Can't see how unles the oil leak is onto the ignition system. I would think that your coil is getting hot and shorting out. Wouldn't hurt to go clean though the whole system to make sure everything is up to par. Walt
