800 hydraulics
Bret4207
08-13-2006 05:59:27
Need a point in the right direction. My 811b hydraulics worked fine until I dranied and changed the fluid in the hyraulic resivoir and adjusted the PTO clutch. Now it does nothing. I had cleaned the filter too. The shop manual gives about 14 dozen possible reasons for the problem . Where do I start? I don"t see a "bleeder" anywhere to get fluid to the pump. TIA
c hess
08-14-2006 19:27:56
 Re: 800 hydraulics in reply to Bret4207, 08-13-2006 05:59:27
\You put hydraulic fluid in right place? Got to confess i dont know if all 700-800 or 730-830 used a common sump as my 830 that holds 18 gal. I know there was a different vent an i believe filler on some earlier tractors an i am thinking maybe you did not fill pto- might have gone in transmission instead . Cant think of areason it is not working if it worked before.
