resister for ignition
INCase
08-12-2006 07:52:52
Did the 800"s come with a resister in line with the coil? Did the later "30 series have this? I see there is a block/resister/terminal strip on the bracket behind the engine under the fuel tank on the 730 but nothing on the 800. Thanks.
Walt Davies
08-12-2006 08:33:59
 Re: resister for ignition in reply to INCase, 08-12-2006 07:52:52
If it has a Distributor and coil and has a 12 volt battery then it has to have a ballast resister in the system to keep from burning the points out.
If it has a 6 volt or 8 volt battery then there is no resister.
Walt
BCnT
08-12-2006 11:27:57
 Re: resister for ignition in reply to Walt Davies, 08-12-2006 08:33:59
also on a 12 volt system...if theres a true 12 volt coil there will be no resistor.
Walt Davies
08-13-2006 22:03:41
 Re: resister for ignition in reply to BCnT, 08-12-2006 11:27:57
I have been a mechanic and worked on all kinds of equipment for 40 years and to this day have never seen a 12 volt system that did not have some kind of resistor with the exception of those with electronic ignitions.
People keep telling me about this 12 volt coil but I have yet to see one actually on a vehicle.
You may be thinking about the early GM cars and truck that had no visable resistor, well these had a resistor wire from the switch to the coil and another plain wire from the starter solenoid to the coil that gave it 12 volts for starting only.
I have also heard of the mysterious coil with a built in resistor.
Walt
Phil (Nj,Az,Sask)
08-16-2006 01:21:30
 Re: resister for ignition in reply to Walt Davies, 08-13-2006 22:03:41
Walt, The IC-14(Echlin) was used on 4-6 cyl low RPM
engines without a Ballast (smaller primary wire = higher resistance). JEEP: 58-59, 60-67, 68-71, Checker Motors 1956-59
"Real" engines used Ballast's to keep heat away from the coil.
Jerry W
08-14-2006 06:11:15
Walt
I think the coil he is talking about is one with an internal resistor. I use them but do not know what if any their original application is.
Jerry
INCase
08-14-2006 04:43:28
Thanks for the feedback. it is 12V. It has a Delco-Remy coil and Autolite distributor. I'll have to look again near the switch for a resistor or resistor wire. There is no visalbe resister anywhere else between the dash and coil. It had been working fine until resently and now I have not been able to get a spark. Even taking the coil output to ground I can't get a spark. Will try the coil and dist. from the 730 to see if works.
