overheating
johndeereman
08-11-2006 15:27:42
is a dc supposed to have a thermostat there is not one in mine it keeps heating up and steaming the antifreeze runs out the top i just got done flushing it out i got alot of rust out of it but havent tried running it yet took the neck off to check thermostat and there is not one there?
Ken in AZ
08-12-2006 08:20:25
 Re: overheating in reply to johndeereman, 08-11-2006 15:27:42
Thermostats were an option on later DC"s but most of the earlier ones did not have them. I doubt the issue is with a thermostat or lack thereof.
My experience has been that the block and head get rust buildup. This breaks loose and ends up in the radiator, plugging it up. I tried several times to get the rust out of a DI (even put a magnet in there and it helped a bunch) but even with good flow through the radiator, it heats when you work it hard. Found a LOT of rust and crud in the block and head of my DH when I tore it down (roughly half a 5-gallon bucket!). Didn"t see much until I pulled the sleeves, and then it was over halfway up the sides of the sleeves, so there was no way I would have been able to flush it out. Your tractor may vary, but this is what I found on a couple of mine.
Ken in AZ
Gene Dotson
08-11-2006 18:27:26
My DC-4 was overheating and getting harder to start. The problem was the magneto impulse spring was broken and letting the timing retard. I replaced the spring with one I got from John Saeli and have had no further problem... Gene
Camboted
08-11-2006 17:26:54
10:1 your radiator core is plugged. We have worked on at least 20 DC's and everyone had some serious blockage. Some still cooled ok, especially the four row cores, but in hard work they all overheated. It is a lot of work, but we rod out about 75% of them, some are junk. So, you may want to order a new core. John Saeli or others who list on the board can get them for you, but they are not cheap.
