1950 VAC Case
J Cashwell
08-11-2006 13:28:02
I have a 1950 VAC tricycle front end with the eagle hitch. Does the rearend and hydraulics for the lift use the same fluid. What fluid is used in the rearend. Are there different resorvoirs. I am not familiar with the lift at all. The lift will raise but leaks down quickly. Any pointers on getting started with the repairs. I need top and bottem 2nd gear. Does anyone know if they are available anywhere. I am also looking for a VT-3776 spring for the disk brakes.
Scott KY
08-12-2006 05:10:42
 Re: 1950 VAC Case in reply to J Cashwell, 08-11-2006 13:28:02
The transmission and the rear axel are together and use 90 weight gear oil. You fill it and check it at the plug on the transmission cover. The hydraulic fluid is in the torque tube in front of the transmission. They recommend 30 weight motor oil in it. Some people use hydraulic fluid. Best advice for the lift problem would be to get a service manual. It will give detailed directions how to troubleshoot your hydraulic system. The problem you have should not be hard to fix.
