Case 411b hydraulic problem
Steve from PA
01-15-2006 10:43:29
Wondering if someone can help. When I lower the eagle hitch on my 411b, it starts to go up before it goes down. also if I work the remote hydraulics lever either way without a cylinder plugged in, the 3 point goes up. It sometimes won't go down then. Anybody know what could cause this? Thanks for any help. PA Steve
Joe (Wa)
01-15-2006 17:00:19
 Re: Case 411b hydraulic problem in reply to Steve from PA, 01-15-2006 10:43:29
I am not sure but it appears that when the control valve spools are in neutral the oil return for circulating the pump may be restricted AND there is some leakage through the lower spool valve or that it is not returning to the fully neutral position.
The restriction could be either or both control valve spools not returning to full neutral or possibly the return oil filter is plugged.
The leak pass the lower spool valve is probably not normally evident until you operate the upper control valve with the remotes blocked as then both control valves would be at relief valve pressure (1200-1300 psi).
Joe
