VAC Hydraulics
Larry Hardesty
08-10-2006 19:46:24
My nephew has a VAC with a loader on it. He took it off and runs to use the hydraulics for a mower on it. Anyone have a VAC or know about VAC hydraulics to explain how to connect the hydraulics for the rear end. I think he will use it just to lift the mower bar.
miplantman
08-16-2006 09:33:07
 Re: VAC Hydraulics in reply to Larry Hardesty, 08-10-2006 19:46:24
was the loader shot?I might be intrested in it?? depends on what it looks like and how far you are from MI.
Larry Hardesty
08-16-2006 12:34:43
 Re: VAC Hydraulics in reply to miplantman, 08-16-2006 09:33:07
As far as I know the loader is fine. I do not know if my nephew wants to sell it or not. He is in central Nebraska.
mj
08-11-2006 08:25:37
third party image
Click the link for more info; click an image to enlarge.
Larry Hardesty
08-11-2006 08:41:26
 Re: VAC Hydraulics in reply to mj, 08-11-2006 08:25:37
Thanks much. Looks very complete. Appreciate it.
Larry
Sam#3
08-11-2006 05:51:03
The VAC came with two hydraulic configurations. The older had the pump driven off the pulley shaft and the later models, with Eagle Hitch, had the pump driven from camshaft gear on the front of the engine. It would help to know which type you have and how much of the original equipment is still there.
Larry Hardesty
08-11-2006 06:24:52
 Re: VAC Hydraulics in reply to Sam#3, 08-11-2006 05:51:03
Sam, Just talked with my nephew. It has the pump in front off the camshaft gear. The hydraulics had been reconfigured for the loader, which he has taken off. He needs to know where the oil resevoir is located and how to connected the hoses to operate the Eagle Hitch. No doubt I could tell you more if I were looking at the tractor. He has it now at the local Case-IH dealer and they are trying to figure things out. The tractor is probably older than any of the mechanics there. Thanks
Larry Hardesty
08-11-2006 06:16:08
Sam, Thanks, The tractor is 40 miles away and is my nephews so I have not paid a lot of attention to it. However, since it has an Eagle Hitch, it must have the pump driven from the camshaft gear on the front of the engine. I have tried to call my nephew but probably will not get ahold of him until later in the day. Thanks
Larry H.
