Steam pumps catologs
David R. Long
08-08-2006 12:54:54
I am looking for a Marsh steam pump for a 1904 20-60 Case compound, and a 1904/05 Case catolog.
Thanks!
Glenn/Mn
08-08-2006 17:12:32
 Re: Steam pumps catologs in reply to David R. Long, 08-08-2006 12:54:54
saw two BB pumps recently on Ebay and you will usally find the catalogs there as well, might want to save your money for a new boiler after Appendix C is re-written, non-code lap boiler will be expensive to own in the years to come
David R. Long
08-08-2006 17:45:46
 Re: To Glenn/Mn in reply to Glenn/Mn, 08-08-2006 17:12:32
What are the changes in Appendix C??? Is this Nat. Board? My inspector has said nothing about this and I just renewed the boiler cert.
Glenn/Mn
08-08-2006 18:25:36
 Re: To Glenn/Mn in reply to David R. Long, 08-08-2006 17:45:46
Yes it is, the formulas for calculating operating pressure factor in the inside diameter of the barrel, I have ran and re-ran these calc's on one of my 65hp ASME rated boilers with the orginal manufacturing data sheet in my hand and a brand new boiler with no corrosion would be around 100 PSI, now 100 years later with corrosion and guess what you will be operating at
