Need Case 530 information
Larry Duley
08-07-2006 19:03:32
I need to know the firing order, location of number 1 cylinder, and location of number one plug wire in the dist.cap for a (unknown year)Case 530.
Also would like to locate a manual for same.
Thanks!
JGarner
08-07-2006 20:15:13
 Re: Need Case 530 information in reply to Larry Duley, 08-07-2006 19:03:32
#1 on distributor is any one you want as long as you know the firing order and direction of rotation. The distributor does just that. When the rotor turns it send fire to the cylinder the rotor pick up aligns with. Pick one and place the other wires in the correct firing order with respect to the normal rotation direction of the dist. The firing order and rotation will be cast on the block somewhere close to the distributor.
