210b head gasket questions
Jas
08-07-2006 10:43:13
The cheapest head gasket I found is right around $40 it would be great if I could find one or a couple much cheaper. I am not sure if replacing the head gasket will fix the water in oil problem so I am going to try that first and then torque it correctly and if this does not work I am going to have to have the block shaved since there is pitting on the top of the block. Any suggestions or cheaper priced head gaskets. Thanks
Dennis/Ohio
08-08-2006 04:21:46
 Re: 210b head gasket questions in reply to Jas, 08-07-2006 10:43:13
From what I've learned on the forum: Pressurize the cooling system with the oil pan off. Probably has liner o-rings leaking.
jas
08-08-2006 08:37:07
 Re: 210b head gasket questions in reply to Dennis/Ohio, 08-08-2006 04:21:46
Do you think that would be a take the engine out type of fix if it is the o-rings around the liner. Its funny because I just bought the tractor and it was claimed to be just rebuilt when actually I really think all they done was took the head off and maybe do a small head job.
Dennis/Ohio
08-08-2006 19:46:54
 Re: 210b head gasket questions in reply to jas, 08-08-2006 08:37:07
I called them liners but I think the Case term is sleeve. I"m sure you can remove the sleeves without removing the engine. Personally I"d rather remove the engine and check everything. Best wishes, Dennis..... ..
jas
08-08-2006 21:33:44
 Re: 210b head gasket questions in reply to Dennis/Ohio, 08-08-2006 19:46:54
Appreciate the info, I know sleeves,liners,removeable cylinder bores, you could probably call them cylinder tubes I guess. I know the engine runs good just getting water in the oil. So I am hoping not to have to do too much more than I already have. I am probably going to try the head gasket first or I might try to slide the sleeves out first but I need to find out if the o rings are replaceable and for how much. Thanks a Bunch Jas
