Model
Kathi Rohde
08-07-2006 06:47:42
Does anyone know what model this Case is and/or what it is worth?
third party image
third party image
third party image
third party image
Kathi Rohde
08-09-2006 10:06:02
 Re: Model in reply to Kathi Rohde, 08-07-2006 06:47:42
I have two of these, they are identical except that one runs but needs a hydraulic pump and the other one does not run. I cannot find any kind or serial number on either one of them
tim casperson
08-08-2006 08:21:24
The front wheel weights are worth almost as much as the scrap value of the tractor. I would take them off and put them on ebay to see what they are worth.
Walt Davies
08-08-2006 08:19:17
Kathie, Look on the back of the engine block on the left side stamped on the part that bolts to the transmission is the serial # it should also have some letters on it that will tell you what model it is.
(Like VAC 51XXXXX or 51XXXXX VAC) it may have differant letter they tell you what model it is.
As far as price it all depends on whether the engine is free(will turn over by hand) and how good the tires are. it could bring anything from about $250 to $500. That mostly depends on how bad the buyer wants it.
Walt
PS you may have to srape the dirt and paint off to read it.
tomturkey
08-08-2006 05:43:52
Kathi Where are the tractors located?
Kathi Rohde
08-08-2006 06:18:52
 Re: Model in reply to tomturkey, 08-08-2006 05:43:52
We are in Alpena Arkansas
Kathi Rohde
08-07-2006 17:59:47
There is no plate on it the markings I can find is VT438 stamped on the engine and VT 161 stamped on the transmission. I appreciate all the help in identifying these, we have 2 of them. We thought they were 1930 A models.
Justin Case
08-07-2006 14:33:17
Based on the photos I would narrow it down to a VAC model year 49,50 or 51. Easiest way to tell if serial number plate is still on the dash panel then subtract 4 from the first two numbers following "VAC" there is further serial number info elsewhwere on this site as well. I narrowed it to 49-51 based on the following observations. 1. Cases 3 point Eagle lift system was not available till 1949 tells us that it is 49 or newer model. 2. The square hole through the frame behind the front wheels for impliment (cultivator mounting) is square not diamond looking like 52 or later models were. 3. I did a search in the tractor photos for VAC and made comparisons to the photos of Case VAC tractors submitted. 4. The latch/ornamentation on the front of the hood dissappeared in later years 1952 or so. Hope this helps I have family's old 46 VAC so I have been reading up on them. Jim
old
08-07-2006 12:12:19
Well its weight isaround 3000lbs give or take a little so as scrap its worth about $150-200. But that said please don't let it go that way. Shoot if you can get it for $200 give or take a little its worth that just in parts plus
tomturkey
08-07-2006 08:36:59
A 1950 VAC. it has the eagle hitch, the grill has been changed from original. Depending on the engine status and tire condition my best guess would have its value at less than 500$. just my opinion
Jerry W
08-08-2006 19:13:53
 Re: Model in reply to tomturkey, 08-07-2006 08:36:59
Tom
I am just curious how you determined that it was a 1950. I could only narrow it to 1949 to early 1951. I own both a 1949 and a 1950 and while I have noticed a few subtle differences I can see none in these pictures.
Thanks Jerry
Augie
08-07-2006 09:04:34
After sitting out long enough to rot the elbow off the exhaust manifold... I'd call it a $50 tractor.
Brian in Ohio
08-07-2006 07:53:01
Looks like a VAC to me.
Is there not a serial number tag on the dashboard?
Kathi Rohde
08-09-2006 10:02:25
 Re: Model in reply to Brian in Ohio, 08-07-2006 07:53:01
No serial number anywhere that I can find
