flambeau red paint, Is it still avaliable?
tractornutjd
08-06-2006 18:25:46
I was at the case dealer and he told me they no longer have flambeau red. Is this true!!
Rick Taylor
08-12-2006 20:31:00
 Re: flambeau red paint, Is it still avaliable? in reply to tractornutjd, 08-06-2006 18:25:46
I have just painted some parts with a very old quart can of Flambeau Red (Farm & Country #9433-060). Painted right next to it with Case Power Red Aeorosol (#B17670N). They looked like a perfect match! I will say that due to the fact that the old Flambeau was faded considerably it didn't look like the same color!
Oh-Oh
08-08-2006 10:15:00
Was at a show a few years ago and saw where a man had three Case tractors all redone by his grandsons. They were proud as peacocks of their tractors as they should be. Only thing was, they were all painted Power Red and stuck out like a sore thumb in the line of Flambeau tractors. I felt sorry for them after all their hard work, the dealer told them Power Red was the same paint. It's not that noticeable until you see the tractors side by side.
John Saeli
08-07-2006 19:17:20
We stock the Flambeau in aerosols, Qts. & Gallons.
Barry Small
08-07-2006 18:29:23
There are two problems people run in to when going to repaint an old case. One is the old flambeau is very faded and hard to get a match. Another is tractors that were mispainted power red a number of years ago. As that has aged people think it is flambeau, but it isn't. I saw tractors mispainted power red over 15 years ago, and people now think it is an old original paint job, or a dealer repaint. If you can find copies of old abe's news it used to often have paint codes for modern automotive grade paints in flambeau red, and specifically said (not power red) Hope this helps.
DurangoCase
08-07-2006 19:06:14
 Re: flambeau red paint, Is it still avaliable? in reply to Barry Small, 08-07-2006 18:29:23
DuPont 44044
PPG 70138
Both are mixable in single stage, Base clear, etc.
dboll
08-07-2006 14:36:13
Power red is a differen't shade. Case does not supply flambeau anymore. Auto paint is much better quality. BPS ect. will fade, it is a poor quality paint. If you go through all the surface prep work spend a little more on good paint/primer unless you are going to ditch the item right away!
JGarner1013
08-07-2006 14:26:51
You might go to your local automotive paints dealer. They used to have all the tractor formulas. DuPont auto finishes does not make colors, they make a base color and mix to a formula to get the color you want. Auto paints dealers have most color charts for very old autos, even Henry Fords famous Model T!! (<:
Roger300
08-07-2006 08:50:11
I've been told Valspar bought BPS (Best Paint Sold) and don't plan on continuing the Case colors!!!That's what I've heard and the local Tractor supply says they can't get it any more. I went to a neighboring town and bought their last gallon about a month ago. Roger
amo
08-07-2006 08:10:26
tracror supply has it in quarts, gallons, etc.
Walt Davies
08-06-2006 20:17:45
They have two paints both called Power Red the one with this number is the Flambeau Red paint. (B17671LF)
Walt
Scott KY
08-07-2006 13:58:02
 Re: flambeau red paint, Is it still avaliable? in reply to Walt Davies, 08-06-2006 20:17:45
The different part #'s indicate spray cans, quarts, and gallons. They are all the same color which is the newer power red.
Walt Davies
08-07-2006 14:05:41
 Re: flambeau red paint, Is it still avaliable? in reply to Scott KY, 08-07-2006 13:58:02
I don't like to argue but I have the can sitting right in front of me with that number and when I painted my trailer it came out Flambeau red.
The dealer showed me a paint chart that shows the differance in the two power reds. If you don't know then go to the dealer and ask them.
I am trying to help epople get the correct paint and I know this to be correct because I have done it myself.
Walt
Scott KY
08-07-2006 14:49:57
 Re: flambeau red paint, Is it still avaliable? in reply to Walt Davies, 08-07-2006 14:05:41
I manage a Case IH dealership and I have asked several people in the Case organization for Flambeau Red and they have told me it is not available. I am just passing on the info from them.
Walt Davies
08-08-2006 08:07:50
 Re: flambeau red paint, Is it still avaliable? in reply to Scott KY, 08-07-2006 14:49:57
Its hard to believe that you manage a Case dealership and don't know that they carry both paints. I have two spray cans and one quart here on my desk at this monent that I bought from my local case dealer.
Ask your supplier to give you the paint chart with chips on it for iron gaurd enamel it will show both Power Reds one is true power red and the other is flambeua red they have diffferant numbers on the can. If all else fails then call my dealer here in Oregon I am sure he can help you get the paint that you want. AgWest at Rickreal, OR 503 623-2363
Walt
Scott KY
08-08-2006 09:41:45
 Re: flambeau red paint, Is it still avaliable? in reply to Walt Davies, 08-08-2006 08:07:50
Tell me what the part #'s are on the spray cans and the quart that you have. I want to look into this. I contacted the Case people a few years ago and was told they did not manufacture Flambeau red any longer. I am not trying to start an arguement, I am just relaying the information I got from the manufacturer, which could be wrong.
Walt Davies
08-08-2006 12:06:58
 Re: flambeau red paint, Is it still avaliable? in reply to Scott KY, 08-08-2006 09:41:45
Scott, Sorry about sounding pised off but I have been having this trouble for the last year about Case having Flambeau Red paint. I kmow its a bit confusing when they call both of them by the same name. (Power Red)
Quart size. (B17671LF)
Spray Can. (B17670N)
Gallon size. (B17670N)
I got the numbers for the quart and spray can off of my cans and called the dealer to get the gallon number.
Walt
Roger300
08-06-2006 18:41:19
It seems they changed the name to Power Red, but when I tried it next to my flambeau red spray paint, it sure looked the same. Just bought 5 spray cans of red and 5 of desert sunset from my local CaseIH dealer. Roger
RandyD
08-08-2006 12:58:19
 Re: flambeau red paint, Is it still avaliable? in reply to Roger300, 08-06-2006 18:41:19
Some NAPA dealers may still be using the old paint system can still mix Flambeau red from the book.
