Sheet metal for a 1950 VAC
Jerry Cashwell
08-04-2006 05:10:26
I am looking for some fenders for a 1950 VAC tricycle front end tractor and some side panels. I have found some side panels off a 1942 and found some fenders but dont know the year. Can anyone tell me what year models sheet metal will fit a 1950
1031D
08-04-2006 06:08:12
 Re: Sheet metal for a 1950 VAC in reply to Jerry Cashwell, 08-04-2006 05:10:26
You are going to need sheet metal off of a 1945-1950 model year. The fenders will fit just about anything, just that the 1942-1946 fenders where 2 piece, and VA/VAI fenders and VAC fenders can sometimes be different heights. I have a 1954 VAC-14 with fenders from a 1947 VAI. The 1942-1944 side panels are flat, whereas the other sidepanels have strengh ribbs in them.
J Cashwell
08-04-2006 07:17:53
 Re: Sheet metal for a 1950 VAC in reply to 1031D, 08-04-2006 06:08:12
What is the difference on the hood and grill assembly with the various models will a 51 or 51 hood and grill work on a 1950 model. I am also somewhat confused on your responce about the side panels and fenders. I am currently looking at a grill, fenders, and side panels on ebay that ends in about two hours so any info is appreciated
1031D
08-04-2006 08:22:29
 Re: Sheet metal for a 1950 VAC in reply to J Cashwell, 08-04-2006 07:17:53
The side panels are not correct for your tractor, as they have the corner fillers, are smooth instead of ribbed, and the black side panel is for the later wider dash. The hoods and grills listed are not correct for your tractor. You should have the grill with the side arm slot in the lower left corner, and the hood with the cast iron lever on top. The last hood and grill listed is a late model hood and grill and it too wide to fit your dashboard. The grill listed will not fit. You need should need sheetmetal that looks like the sheet metal on #180014507552 if your is a 1950. If yours in a 1950, the serial number should be bewteen 5400001-5408987 according to CASE company records from their office in Racine. Both sets of fenders listed for a VAC will fit, but I am not sure on set#160014252162 as they appear to be VAO/VAI short fenders for 24" tires.
