Eagle Hitch on Case 311
Jerry
11-16-1999 06:46:43
I recently bought a 1957 Case 311 tractor with an Eagle Hitch. I am now in the market for a blade, bush hog, etc.
Is the Eagle Hitch standard size? Will the implements fit the hitch or will they have to be modified?
I have been reading a lot about the Eagle Hitch at this site and am begining to wonder if its going to be difficult to find implements to use on the tractor.
Thanks in advance for any info.
Scott
11-17-1999 07:40:35
 Re: Eagle Hitch on Case 311 in reply to Jerry, 11-16-1999 06:46:43
I also have a Case 311 with the eagle hitch. I don't know the year of the tractor. I use a blade and a bush hog with it. In light of the previous reply, I must be doing something wrong, because I find it a pain to use. Apparently, after you make the connection you have to back up the tractor for the hooks to latch properly, when I do that the implement (bush hog) just backs up with it and the hooks don't latch. Same thing when disconnecting. I end up having to push the bush hog by hand. Unfortunately the construction on my blade makes it so that I have to have the hooks closed when setting it up, so I can't leave the pins in the blade anyway. The bright side is that it fits. If there is an operators manual out there, I would like to get it.
Larry
11-17-1999 08:47:52
 Re: Re: Eagle Hitch on Case 311 in reply to Scott, 11-17-1999 07:40:35
In the Market Place section of Yesterdays Tractor home page you can order a operators manual for your tractor.Read the section on how to use the eagle hitch.Then go out and practice a little hooking up to your implements.After you get on to doing it right you will like the eagle hitch a lot better.I used to have problems too until I got a operaters manual for my tractor.Good Luck : )
Scott
12-08-1999 08:26:44
 Re: Re: Re: Eagle Hitch on Case 311 in reply to Larry, 11-17-1999 08:47:52
I got the owners manual and it shows that there are supposed to be some cables hooked up to the hitch latches. Mine are missing. How are they connected and are there supposed to be any springs on the latches?
Larry
11-16-1999 08:49:20
I realy like the eagle hitch.I think it was concidered a cat. 1 hitch.That means that anything with a 7/8" pin on it should work.Measure the width of the implement you are going to buy just to make sure it will hook up ok.The reason I like the Eagle hitch so well is that you can hook up your implements without getting off the tractor.Unless you have a pto to hook up then you will only have to get off just that once.Do your self a favor and get a operators manual for the tractor.It will explain the full function of the Eagle hitch.
