Case show
INCase
08-02-2006 09:49:08
THere is a tractor show next weekend AUg 11-12th in Lagrange, IN that is featuring Case this year (FYI). I don't have any other info right now.
Sara S
08-04-2006 07:30:23
 Re: Case show in reply to INCase, 08-02-2006 09:49:08
We have an old Case tractor Model 441 (think it's a 1964 model, but not really certain) that we are wanting to sell. Condition is operational but brakes are not good. Some rust, particularly on the engine hood, but starts and works reliably.
Is this a model that collectors would be interested in? What kind of price do you think we should put on it?
Gene Dotson
08-04-2006 09:03:14
 Re: Case show in reply to Sara S, 08-04-2006 07:30:23
Sara;
Many factors will influence the value of older tractors. Condition of sheet metal and tires are 2 very important and expensive items. Does the tractor have triple range transmission or live power take off? Is the engine and drive train in good shape?
How aboutpaint and appearance? Type of front end, wide or narrow?
Location is also very important, especially now with high fuel prices. Where are you located???
The 430 series are a desirable tractor. The value may be about $350.00 for a tractor that needs work to $2200.00 to $28.00 for an excellent original well equipped or good restored tractor... Gene
Sara S
08-04-2006 11:41:30
 Re: Case show in reply to Gene Dotson, 08-04-2006 09:03:14
Probably closer to the lower end. Significant rust on the sheet metal - surface rust w/ no holes (that I know of - but looks orange instead of white). Wide front tires. One of back tires recently replaced. Other back tire probably needs replacement soon. Power take off. No idea about the transmission. Don't really know what to say about the engine and drive train except that it has always done what we asked of it and doesn't make any strange noises, but we're no experts. Brakes will slow tractor down, but not hold it. Location: Rockingham Co., NC.
Gene Dotson
08-04-2006 16:15:03
 Re: Case show in reply to Sara S, 08-04-2006 11:41:30
Sara;
The 430 is one of my favorite tractors. I sold a nice one with new tires and sheet metal redone. Mechanically good. Had a 2 bottom plow with it. I sold it for $2200.00. Wish I had it back now.
A tractor that runs and drives alright will be worth at least $1000.00 to $1500.00. Really hard to appraise from a distance. Some good pictures would help. Woulf be happy to look them over if you wanted to send them.
My e-mail is [email protected] .... Gene
Mn Dave
08-04-2006 05:03:53
Don't forget the J. I. Case Collectors summer show in Le Sueur, Mn. on Aug 25-27. Last time we had the JICCA here was in '91. Looking for a great turnout of Case stuff.
Gene Dotson
08-02-2006 12:48:26
Got that show on my calendar. The dates are Aug. 10 to 13. Haven"t decided which tractor I wil bring yet. Hope to meet some of the guys from northern Indiana and southern Michigan. Look for the orange shirt and hat... Gene
dctom
08-03-2006 16:44:16
 Re: Case show in reply to Gene Dotson, 08-02-2006 12:48:26
HOPE TO BE THERE FRIDAY MORNING, OLD MAN WITH A CANE TOM
Walt Davies
08-03-2006 11:10:56
Gene, Now is a good time to show off that LA you have been rebuilding with the LP head.
Walt
Gene Dotson
08-03-2006 12:17:12
 Re: Case show in reply to Walt Davies, 08-03-2006 11:10:56
I may just do that Walt. Then I can leave it off at Portland on the way home and maybe take another tractor when I go to camp. I will be running it on the seperator at Portland for the Girard Family threshing crew.
I showed it off at the Greenville show and really did a good job on the sawmill. I figure I have about 85 horsepower with it now... Gene
Don Rudolph
08-04-2006 07:40:29
 Re: Case show in reply to Gene Dotson, 08-03-2006 12:17:12
Gene,
How many gallons of gas per hour? Don
Gene dotson
08-04-2006 08:52:55
 Re: Case show in reply to Don Rudolph, 08-04-2006 07:40:29
Don; Running 18.5 hours on the sawmill I used about 55 gallons of gas. That includes idle time and running when not under load. Under full load and full throttle, it will likely use about 6 to 7 gallons per hour. Running the sawmill, I could only run about 2/3 throttle due to too small pulley on the saw shaft.
We were running with a 6 inch belt and we did manage to stretch it some. Was also shedding some threads from the sides. Hope to run with an 8 inch belt next year... Gene
