430 PROBLEMS
DWIGHT(IKE)
08-02-2006 07:56:08
I HAVE A CASE 430 DEISEL I RAN IT OUT OF FUEL THEN FILLED IT AND IT DID NOT WANT TO START. ANY IDEAS OF WHAT IT COULD BE. THANKS.
TexasWren
08-04-2006 09:44:21
 Re: 430 PROBLEMS in reply to DWIGHT(IKE), 08-02-2006 07:56:08
When I ran into this on my 830, I was way out in the field, and it was a pain to refill it (would have had to carry 30 gallons out there). So I filled the gas tank about halfway, and used a brake bleeder hand vacuum pump to suck the air out of the bleeder screw holes in the filter housings. It worked, but it was a pain.
Doesn't the 430 have a 3-stage filter just like the bigger ones? A single stage automotive filter would be nowhere near good enough, radically shortening the life of the injector pump and injectors. That's real important to fix.
R. McGuffin
08-03-2006 19:15:03
You might want to check and see what the fuel level in the tank is after adding fuel. With the tank completely empty, it takes more than 10 gallons of fuel to get the level above the top of the filters. You have to have the fuel above the top of the filters to ever get all the air out of the filter housing. I ran into this last year on my 430.
dwight(ike)
08-03-2006 20:31:58
 Re: 430 PROBLEMS in reply to R. McGuffin, 08-03-2006 19:15:03
i still can not get fuel to past pump, it is missing entire fuel filter assembly and has some little car filter. is there a bleeder on the fuel pump. i put about four gallons in it, i will try to fill more to see if it helps. thanks, i am looking for a fuel assembly now.
Walt Davies
08-03-2006 11:08:55
I sure hope that you replaced that car filter before starting it again. also check to see if any of the filter a migrated to the pump. It will show on the filter if it has been eaten away by the diesel.
Walt Good Luck on this one.
dwight(ike)
08-03-2006 12:38:45
 Re: 430 PROBLEMS in reply to Walt Davies, 08-03-2006 11:08:55
doe you know where i can fing one its a 1961 430 utility tractor with the shuttle transmission
Walt Davies
08-03-2006 15:09:39
 Re: 430 PROBLEMS in reply to dwight(ike), 08-03-2006 12:38:45
Dwight, check with your Napa auto parts store they can cros referance it to a new filter.
Walt
dwight(ike)
08-03-2006 07:44:08
thanks for all your help, it does not have the proper fuel filter it looks like some one replaced it with a car filter. i will try bleeding it through the injectors and see if that does it. thanks again.
mowr
08-02-2006 19:06:18
If you haven't been thru this before, here's the procedure: don't crank it until there is fuel in the tank, fuel valve is open, ALL the air is bled (by means of the bleeder screws) out of the filter assy(s), then the injector pump. Next, loosen the nuts holding the injector lines to the injectors, make sure the fuel shutoff knob is pushed in (so the injector pump can pump the fuel), open the throttle lever all the way (so the pump can pump the maximum amount of air out with each stroke). Make sure the transmission is in neutral and set the parking brakes. Once you've taken all necessary safety precautions, crank the engine over 15 seconds at a time with one minute of cooldown time in between for the starter (or whatever your manual says) until only fuel (no air) is coming from at least one of the fuel lines. As soon as each/all flow(s) fuel, snug the nut(s) down and crank engine. When it starts, throttle down to normal speed.
Roger (Mi)
08-03-2006 03:21:36
 Re: Roosa-Master pump is self bleeding in reply to mowr, 08-02-2006 19:06:18
(mowr) has covered it all, except it's NOT necessary to crack the injection lines at the injectors to bleed them. Unlike a number of other injection pumps, the Roosa-Master will self-bleed those lines. Leave the hood on and follow the rest of (mowr's) advice.
Mike Veen
08-02-2006 11:27:03
Try bleeding out the fuel filter or the fuel bowl buy the filter,then try cracking some fuel lines on the pump.Some times there is a bleeder on the pump.Try one at a time,it should bleed out,but make sure there is fuel in the filter first.
dwight(ike)
08-07-2006 07:53:56
 Re: 430 PROBLEMS in reply to Mike Veen , 08-02-2006 11:27:03
well i got it started thanks for all your help
