Groove in 188 Crank Pulley
Fred68
08-02-2006 05:43:45
I am replacing the front crankshaft seal in a 188 diesel and I noticed a grove is worn into the crank pulley. Is this groove supposed to be there? I didn't think it was and I was going to have a machine shop weld it up and turn it back down smooth.
Fred.
Walt Davies
08-03-2006 09:06:37
 Re: Groove in 188 Crank Pulley in reply to Fred68, 08-02-2006 05:43:45
Fred, Any compitent Machinist should be able to run a reamer though it to bring it back to size at a lot less cost than sleaving. We are not building rocket here it doesn't need to to be perfect.
Walt
Bob
08-02-2006 09:18:27
See if there is a Speedi-Sleeve that will fit.
Welding it up will tend to shrink it, making it TIGHT to press onto the crankshaft, so be carefull about that.
Fred68
08-02-2006 10:19:41
 Re: Groove in 188 Crank Pulley in reply to Bob , 08-02-2006 09:18:27
Thanks Bob. That's exactly what my machine shop said. So, they are going to sleeve it.
Thanks.
Walt Davies
08-02-2006 07:05:38
Fred, On older equipment that had leather seals this was a common thing to happen. The leather was rather hard on the soft metal of the pulley.
You are correct in what to do with it. Walt
Fred68
08-02-2006 08:18:45
 Re: Groove in 188 Crank Pulley in reply to Walt Davies, 08-02-2006 07:05:38
Thanks for the info, Walt. I wondered how a rubber lip seal would have worn into it, but that makes sense.
Fred.
