oil pan removal
amo
08-01-2006 15:03:06
WHAT IS PROCEDURE TO REMOVEW OIL PAN ON A 1952 VAS, DOES IT NEED TO BROKE INTO OR THE FRONT END REMOVED? THE PAN WILL NOT COME DOEN DUE TO THE OIL PUMP CATCHING ON THE PAN. THANKS
Jim Yadon
08-02-2006 05:17:54
 Re: oil pan removal in reply to amo, 08-01-2006 15:03:06
Good morning, The only way to take off a oil pan on a VAS is take the front end off the tractor. Because the yoke from the front end isn't large enough on the drop the pan through the center of the yoke. It narrows to much to be able to drop the pan. And you can't spin it out of the way. Yes the oil pump and screen are in the way to remove the oil pan. There is nothing internally incorrect. Hope this helps. Jim Y
watsonsgotit
08-01-2006 18:55:10
Amo, The oil pan should drop straight down without taking anything else loose. If it is catching on the oil pump, you may have internal problems.
boston bean potty
08-09-2006 14:51:55
 Re: oil pan removal in reply to watsonsgotit, 08-01-2006 18:55:10
well??? whos right here???
