case 800 vs 830/730 gas manifold
Jacob Meuth
07-30-2006 20:38:19
Does anyone know if a 830/730 manifold for a gas will fit on a 800 motor i know the displacement is different but are the heads different? Or does anyone have a manifold for a 800 gas? Thanks Jake
jaker2
07-31-2006 10:20:31
 Re: case 800 vs 830/730 gas manifold in reply to Jacob Meuth, 07-30-2006 20:38:19
I am currently runnng a 400 diesel intake and 400 gas exhaust manifold on 830 gas heads. I am thinking the manifold will interchange but I do know the 830 block is wider than the 100 series. I am not sure if the 730 is the same.
INCase
07-31-2006 05:48:12
That�s a very good question that�s been asked a few times before. I�ve seen comments here that the �30 series and the �00 series heads and manifolds are not interchangeable. I�ve also heard that from a local salvage yard as well (I question if they really knew). However, I�ve also been told by an old Case dealer that they are interchangeable. And I have seen an 800 with one 800 head and one 730 head (gas tractors) and it had an 800 manifold. I didn�t hear it run to see if they had manifold mating issues though. I�ve also seen a 930 CK gas with an 800, 730 (930) and a 3rd head with a different casting number (24543) on the side (however the number cast in between the water manifold ports was the 730 number). Sorry, I probably haven�t answered your question.
